I setup internet with PPPoE client by Winbox tool (without default config and not easy setup).
Everything work fine in 1 day. But after that I see the Tx off PPPoE Client link go up without reason (don’t have any traffic from inter LAN) and CPU work more.
I have used sniffer tool on WinBox to check, and see many packet 34916 is send from my internet card’s MAC address to another MAC.
Does anyone know why this happen? Please tell me, thank you so much.
Can’t see the picture on mobile from some reason. Will have a look later. See the torch and profiler meanwhile to know more about the traffic and what consumes the cpu. Is the line exhausted by the traffic?
in WinBox, go to “Interfaces”, open the PPPoE interface window by double-clicking and click on “Torch”.
There you can see what traffic is flowing on this interface.
The next steps depend on what kind of traffic you’ll see.
My approach to port 53 in input chain from wan interface is to drop udp and tarpit tcp.
Using also bruteforce login prevention. And all other rules are mainly individual to my needs according to the places where the routers are and what traffic should pass trhu. None can give you general “secure” rule set that could fit your needs.
