I have created mikrotik hotspot using crs125-24G
Its working perfectly fine.
Please tell how do i configure wireless ap with this
So it can be used on mobile phone.
I have
1)unifi ac lite
2)tp link eap110
3)dlink dir610
If it is posdible please guide me how I can protect hotspot from “angry ip scanner” or information of active ip/mac in order to prevent hack.
I was planning that first customer have to put voucher code for unifi then mikrotik id and password.
Please reply or guide on anything you know above!
Thank you!
I have the same issue.
Is it possible to configure on the CRS125-24G-1S-RM (there is no wifi interface in the machine) an external AP connected via lan?
thanks for a hint if it is possible yes or no?
Thanks in advance.
G.
You can use CAPSMAN on this device to manage external Mikrotik APs.
Please read this: https://wiki.mikrotik.com/wiki/Manual:CAPsMAN
