i have no dDns so i cant connect internet.what can i do please help me?i m waiting for you. thank you
Hi
Did you modify your dns settings like this? If not, then it’s a consequence not a reason. You probably lost your lease / session and hance dns servers have been removed from dns settings, as your uplink is down. If you get your uplink back up, these should be auto added.
Use just static servers: 8.8.8.8 and 8.8.4.4.
It may be as simple as that, but if these are added as part of dhcp config, it won’t do anything, as this means that uplink is down
I can not change the DDNS settings.i try change static ip but still same.is there an another way?
can you ping 8.8.8.8 or 8.8.4.4?
so in terminal, wirte:
:ping count=4 8.8.8.8
Do you get replies?
You don’t have to add them as a part of dhcp config. Just assign them statically in DNS config and they will be in dhcp config automatically. And of course, you have to have a route to 8.8.8.8.
i can’t get a reply
what is the output of?
/ip address print
and
/ip route print
You’re missing the point, the WAN might be down, adding dns’ ip will not fix that…
Then it’s better be up ![]()
