i have problem to make my range up to 1022
if some one can help me make my range up to 1022. I only have at this moment 254 of range which does not help me at all. Please help me
Looking at all your other posts on this forum you should basically have all info needed.
First, adjust the subnet mask in your IP address:
Change it from 192.168.88.1/24 to 192.168.88.1/22 - or whatever your subnet is.
Then change your DHCP-Server network definition to the /22 subnet
Then adjust theIP pool for that dhcp server to match the addresses.
Done.
Shouldn’t take more than 15 seconds.
-Chris
There may also be access rules/nat etc that uses subnet.
So look everywhere.
Post you config and it should be easy to point out what to change.
GOT IT THANK YOU VERY MUCH
