I have router rb 433ah with 8gb can i make proxy
I have 433ah with 12 users network can i make proxy server what i need to do. I have 8gb micro sd card inside in rb 433ah can i use this space for proxy help me please thanks :confused:
some one can help me with this please
  1. how to configure proxy: http://www.mikrotik.com/testdocs/ros/3.0/pnp/proxy.php
  2. to add the microSD card as the storage drive, use the “store” menu:
/store> add disk=sd type=web-proxy
where i shud write this code?
:confused:
in the router :open_mouth: :confused:
[andriuxa@Kns-Vaidas] > store
[andriuxa@Kns-Vaidas] /store> add disk=sd type=web-proxy
input does not match any value of disk
[andriuxa@Kns-Vaidas] /store>>
we have 4gb micro sd HC
“disk=sd” was just an example, you don’t need to copy it directly
choose the name of your own disk
if you are not sure, type disk= and then hit [tab][tab] to see available options
nothing i thing the router not recognized disk he see only system disk
go into “/store disk” type “print” and see if it’s in there. if yes, format it from that menu
NAME TOTAL-SPACE FREE-SPACE STATUS
0 S system 61440KiB 30020KiB ready
we did not find 8gb we put 4 gb mikcro sd hc he don't see itt
as you can see here, there could be some cards that are not supported by RouterBOARD:
http://wiki.mikrotik.com/wiki/Supported_Hardware#Memory_cards
Try to find another brand or size, and see if it works. if yes - please send to support list of cards that you tried, and the results.
