I’m going to make a new project using MT RouterOS , i’m going to sell shared packages of bandwidth , exactlly as the internet through satellite providers do , but i’m going to do it in my area Wirelessly , the sharing ratio is 10:1 , for example : 10 users r sharing a max of 256/128 , other 10 users sharing 512/128 , and so on , its the way we recieve shared bandwidth through satellite , now , how can i divide the band with MT ? is PCQ good enough to do this ? i mean : mangle == queue type == queue tree ?? and if its ok , can any body tell me the exact setup , i’m a little lost with the difference between Forward and prerouting !!
after solving that problem , now , i want to give http the higher priority i know how but how can i mix it with the previous setup of deviding the band ??
i hope its clear to you all , and i hope some help soon
new idea !!! in simple queue i can add more than one IP to the single queue … so i can put every 10 users in one simple queue , any idea ??
yes, use simple queues with PCQ creating one simple queue for each user group
how to do that, pleace, read manual here
this is EXACTLY what i want to do.
i get 512kbps down and 256kbps up and would love to learn specifics on how to do this.
i use hotspot with dhcp though cause it makes my life easier.
but user groups are not allowed in simple queue !! i can just add one IP each time , let’s say i have a group (192.168.1.100 - 192.168.1.160 ) should i enter 60 IP in the simple queue target address?? i dont know why in the whole MT theres no mention to a word GROUP ? we can find only adress-list !!!
we can find Contention Ratio in the manual , and thats what i need , but they only metioned it here !!! no examples !!!
note, i’m not using hotspot ..
by the way , is there anyone from MT team can solve our problems ??
