i just noticed store is gone and my userman is error
where is store gone to?
[admin@mikrotik] > /store
bad command name store (line 1 column 2)
userman is also error
[admin@mikrotik] > tool user-manager database print
database is not acceseble, yet
[admin@mikrotik] > /tool user-manager database print
[admin@mikrotik] > /tool user-manager database rebuild
Can take a while. Console may not respond while in progress. Rebuild user-manager
database? [y/N]:
y
Rebuilding user-manager database
File does not exist!
any idea how to fix this? i can’t check what is going on with userman database since store can’t be opened anymore, i dunno since what version.
i hate to do this, but it happens again, i answer my own question. i know now since when /store doesn’t work anymore.
6.20 (2014-Oct-01 10:06) changelog says:
*) stores are replaced with folders and disks are now managed under /disk menu;
ok. 1 question solved, but i still dunno how to fix the userman. i tried to manually copy sql files from other mikrotik, still doesn’t work at all.
