I need a vpn connection to watch norweigan tv
Hy
I would like to setup a vpn server so that when I’m abroud I can watch norweigan tv (you have to have a norwegian IP to watch it over the internett). Just like strong VPN does.
My setup is like:
Ether 1 is internett and it is masquerade
bride 1 (ether 2-5) is lan
I would like to jus PPTP but it can also be L2TP. the client is a Ipad.
Are you asking a question or just telling us what you are doing?
If you are asking a question, just use the wiki examples:
http://wiki.mikrotik.com/wiki/Manual:Interface/PPTP
Hy
Tanks for the reply. Yes I’m asking how to setup this. I have tryed the connecting remote client but I can not get it to work. Do I need to do eny changes in my firewal?
If you have pptp server enabled and you are not blocking it in the firewall, then it will work. If it doesn’t work, then something between you and the mikrotik is blocking it, likely blocking GRE.
