I need help 951 router - factory reset settings
I have a question … I bought a WiFi router 951 and after several attempts to set it up, the device stopped working script that restarts after asking me about the router settings. How do I return the router to its factory settings. Reset button does not return to absolutly factory settings. What should I do?
Or you can ask backup fille with the factory settings of 951. As the router to re-write or edit the contents of the script default сonfiguration?
