Please, does anyone where knows how I can configure my starlink mini with my mikrotik hap ax3. I would love if Anyone can help me remotely
What is the goal of configuration?
Does Starlink work? Not?
What is the HAP configuration? Is it a router? Just an AP?
What does not work?
What configration you already did?
I have the regular Starlink.
I connected a PoE to it (not the router from Starlink), and configured the AP (here RB5009) as DHCP client. That is all.
You’ve two choices: use one of the Ax3 WiFi channels in bridge mode to connect to the Mini’s WiFi or connect it using Ethernet. Ethernet is more reliable. If connected via Ethernet assign a dhcp client to the port it’s plugged into, set up AX3 WiFi then either bridge everything (which leaves DHCP to the Starlink) or bridge everything except Starlink port add DHCP server and ip to bridge, and continue to set up like any other router.
Thank you! The goal of the configuration is to harness my Starlink Mini to the Hap AX3 so that I can give my children unique passwords and monitor their usage.
Yes, Starlink is working perfectly. The Hap is new and there is not configuration yet on it. I want it to make it an ap since it has wife connectivity.
No configuration yet.
Thank you for your response. I am not a tech savy and i know nothing about mikrotik configuration. I will be glad if Someone can help me configure it remotely.
You really don't want that, and many will be reluctant to do so anyway for obvious security reasons. There are plenty of Youtube videos to help, and Mikrotik's built-in 'Quickset' function will serve your purposes anyway. Best of luck!
