As indicated in the subject, I have these devixes at home, RBSXTR&R11e-LTE and RB952Ui-5ac2nD. My concern is that, is it possible to power the LTE from the hAP AC lite on port 5 and at the same time receive internet at that same port? As per port configuration, port 1 is the poe in and internet. I want to minimize the number of LAN cable and power outlet usage. Thanks
Yes you can!
The original device power supply will then power both at the same time. I’ve just one cable going to my SXTLTEkit: rj45, carrying power, lte data & vlan for management.
Thanks for the reply. I will try this set up ASAP.
