i need help, i have a problem :@ radius :@
Hello friends,
I installed intel version of os 5x mikrotik with intel. I aim to collect hotspot, dhcp, webproxy and user manager on a server. I use a cable modem. I can install hotspot,dhcpve,webproxyi but I can’t install usermanager. When I install usermanager, I can’t describe the users by lan and the radius server is not responding. I need your help friends,please…
you said you can’t install user manager then you says “I install user manager” !
this is two : A. Install user-manager package B.setup user-manager (after upload User-manager package)
Which one?
for what you need User-manager ? Hotspot, PPP, …
I have a wired my network users to control and limit
hotspot and set up the web proxy cache, keeping I want to do with this system os MikroTik.usermanager also easy to add users to print this for a more detailed and installed with User Manager User Manager can access the WAN.But Ethernet can not access from the entrancecan not login with the user you specified radius from the hotspot sermanager
Sorry my friend. I can’t understand you, but I have a placed here
http://forum.mikrotik.com/t/user-manager-configuration/51211/1
step by step configuration for User-manager to work with PPPoE server. I hope it will help you.
