I accidentally deleted the Switch Management Vlan, I would like to know if I can recreate it by console, my mikrotik switch is a CRS326-24G-2S + using SWOS, I connect by console but it does not give many options or a CLI, what can I do, the switch is in production and I cannot erase it to start again, what can I do ?, thanks
If multiple ports of it have IPs, just try to connect to each IP via Winbox or Webfig.
If possible also by connecting the PC to the right port, if the above step don’t work.
