i need help plz help me
hi everybody i have question and i need help
i have mikrotik router hotspot and i need to forward some ports to special (ip) like 192.168.0.148 and i read read subject in this forum about it definition in this page
http://wiki.mikrotik.com/wiki/Forwarding_a_port_to_an_internal_IP
so
1 - i don’t know where to put this code ??? is it in termnal in winbox or what ???
2- what is (69.69.69.69 ) mean ?? is this extrenal ip or what
thanks alot for your reading
The example must be entered via a terminal session via serial port, direct telnet or WinBox Terminal session.
The text of the example states that 69.69.69.69 is the example public IP address, replace this with your public address.
[quote=“cmacneill”]The example must be entered via a terminal session via serial port, direct telnet or WinBox Terminal session.
thanks alot for your care for help me
sorry i don’t know about telnet do you mean make connection by telnet and put this code ??? so if you mean that how can i do this
thanks again cmacneill
read all topics here:
http://wiki.mikrotik.com/wiki/Most_basic_questions
and here:
http://www.mikrotik.com/testdocs/ros/2.9/guide/basic.php
you have to learn the basics before you can use the firewall
thank you so much for help me i gree with you i should learn basics before use firewall thanks again
