I need help to activate cash (in RouterOS 3.11)
I’m not an expert in the system MikroTik ,So I need The method of operation cash (storage Websites).!!!
How can I activate the cash is correct ؟؟؟؟؟؟؟
I have tried many but failed to activate the cash
Please explain to me ؟؟؟؟؟؟؟؟؟؟؟؟!!!
I using Router 3.11 (PPPOE)
ether1 : 113.112.114.9
Gateway: 113.112.114.10
DNS: 217.66.226.8
: 195.68.208.230
One command:
[admin@MikroTik] ip proxy> set enabled=yes port=8000 max-cache-size=1048576
Taken from: http://www.mikrotik.com/testdocs/ros/3.0/pnp/proxy.php
Thanks normis;
I did so but did not work with me.
Please see the pictures, and I corrected settings
1-
2-
3-
When I add This NAT, the page WebSait Not open with me .
4-
5-
Please Help me and thanks very
did you enter proxy address in the clients browser settings?
look at :
1- http://up100.arabsh.com/files/l72h0tg5catno96bzskc.jpg
2- http://up100.arabsh.com/files/ikyknegqinwqukehbaqt.jpg
3- http://up100.arabsh.com/files/2zgineh8o0jadi09v2qa.jpg
4- http://up100.arabsh.com/files/hagsr23oyf3reebnbfnc.jpg
5- http://up100.arabsh.com/files/cs9ds350hn9wb7vcph16.jpg
ok, all looks fine, but your port has 8080 two times. remove the other one. what happens when client opens browsr?
Problem is not solved … Please correct me settings
and There is also a problem with NAT
any help please
there is no problem in your config. did you do what I asked?
Yes, but does not work, ar you have explained clearly ?
Write me right configuration settings, please
post your config first, from console:
  1. proxy settings
  2. NAT rules
thank you very much I succeeded in operating cash .
Only one problem Where do I put this :
“:\.mp[3g]$”
I know you possess considerable experience in the system MIKROTIK
I want you to help me in Setting the cash To Work as an excellent way without problems.!
Thank you Thank you Thank you
my Hard :80G
Ram :2mg
This may help:
http://wiki.mikrotik.com/wiki/How_to_make_transparent_web_proxy
Dear shereer,
I’ll be very happy to know how to active CASH instead of CACHE. Cause I’m bit short of CASH in my business. Huh huh huh never mind just joking.
hulk-bd
Maybe you need to host some more WebSait’s :smiley:
