hi all ihave problem i dnt know is from my provider or config my router pc 2.9 when i made a ping for dns many timeout i found i had only 30 users plz
Is your DNS in your LAN or from your service provider?
Try using nslookup for test your DNS query speed.
You can also use MK as slave DNS. And also putting the Local IP in PPPoE DNS field.
Rafiq…
http://www.linux.org.bd
thanx for reply my dns is from porvider i use hotspot and enabel web proxy-test plz
