i want mareg 2 adsl line
but i have many static ip
so what you sugesst to me to do
sorry for my bad english
Public or local?
Public
And how do you expect it should work?
we want marge 2 line with full access to any server in our network from any place
Hello almoslem2005,
Please see at the next line for get more detailed informations!
5 + 5 = 10 but 5 MBit/s + 5 MBit/s = 5 + 5 and not 10 MBit/s ok?
There are 2 different way that are matching to realize your plan, but only
and please reads one more again only if your ISP (internet service provider)
is also offering you that as a service by his own!
One of this variants is using the PPP Multilink Protocol
or also called (MP/MLP/MLPPP) it must be supprted on both ends
so that means at your router and on the other side at your ISP.
Multilink_PPP
MikroTik online manual - MPLS
The other variant would be the VPLS setup,
VPLS is a Layer2 service based on the MLPPP
and it must also likes the first variant supported
by your router and you ISP.
VPLS Wikipedia
MikroTik online manual - VPLS
This both methods will do this 1 MBit/s + 1 MBit/s = 2 MBit/s
But you are also able to realize it over BGP set up.
Or BGP in combination with VRRP.
MikroTik online manual - BGP
MikroTik online manual - VRRP
If your ISP is not able to sort you or plain to offer you MLPPP or VPLS
you would not be able to use it, rather then I would suggest you to
use a load balancing method offered by MikroTik RouterOS.
Different methods are:
- policy based routing
- service based routing
- session based routing
