thanks fevi but i cant understand how apply on my point to point link
as well as at access point .
here is the access point details
[admin@radio1] > /interface print detail
0 R name=“ether1” type=“ether” mtu=1500 l2mtu=1526
1 R name=“wlan1” type=“wlan” mtu=1500 l2mtu=2290
2 R name=“bridge1” type=“bridge” mtu=1500 l2mtu=1526
[admin@radio1] > ip address print detail
0 address=192.168.1.51/24 network=192.168.1.0 broadcast=192.168.1.255
interface=ether1 actual-interface=bridge1
[admin@radio1] > ip route print detail
0 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.51 gateway=bridge1
gateway-status=bridge1 reachable distance=0 scope=10
[admin@radio1] > ip firewall export
jan/07/1970 12:13:01 by RouterOS 4.10
software id = 6F3F-IRVF
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
And the this is the p2p print detail–
0 R name="ether1" type="ether" mtu=1500 l2mtu=1526
1 R name="wlan1" type="wlan" mtu=1500 l2mtu=2290
2 name="wds1" type="wds" mtu=1500
3 R name="bridge1" type="bridge" mtu=1500 l2mtu=1526
4 DR name="wds2" type="wds" mtu=1500 l2mtu=2290
0 ;;; default configuration
address=192.168.1.54/24 network=192.168.1.0 broadcast=192.168.1.255
ip firewall export
# mar/14/1970 13:43:52 by RouterOS 4.5
# software id = 4YHJ-U939
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
print iproute detail
bad command name print (line 1 column 1)
[admin@p2p ppcompound] > ip route print detail
0 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.54 gateway=bridge1
this is all
now you can see the all things that you want
now i want to know how to configure the firewall on access point and p2p routers.
can you give the sample firewall rules and also for virus prevention ..
thanks u very much
New Microsoft Office Word Document.docx (56.6 KB)
