I need script
hello
I need script run every second or every Minute
if user “admin” is active in pppoe
disable interface “lan”
else
enable interface “lan”
I need it necessary
Try it:
:local adminpppoe [/ppp active find name="admin"]
:if ($adminpppoe!="") do={ \
:log info "enabling"
/interface enable lan \
} else={ \
/interface disable lan \
Use system scheduler to run it how often as you like
