I need seriously help!
I need seriously help for mikrotik-to-mikrotik VPN and a few extra things. Can somebody help me over e-mail/gtalk/msn ?
what specifically do you need help with? Have you tried something that hasn’t worked? maybe you should post some details about your setup.
/ip address print
/ip firewall export
/ip route print
(between code tags)
I’m trying to connect different sites to a central site with VPN. I started by trying to connect one of the remote locations to the central and actually i did it with PPTP & EoIP Tunnel but there are serious problems.
I’ll explain and post the configurations but first, please give me advice for a VPN method. Which is the best for connecting more than two sites ?
The purpose :
There are one central location and 5-6 remote locations. All of the locations have two WANs and one LAN at least. I also need to do load balancing between these WANs but this is not my first priority. My first priority is to connect one remote location to the central.
What i did ? :
I followed the following videos and created everything i need. It seems to work but not as i expected. When i ping central’s GW from one of the remote locations first, the central can’t ping to the remote location’s GW. When i ping the remote location’s GW from the central first, the remote location can’t ping the cental’s GW. It seems there is a one way connection. So, it is useless for me.
There is an annoying “Encryption got out of sync” error also. ( here is the topic : http://forum.mikrotik.com/t/pptp-encryption-got-out-of-sync/43992/1 )
http://www.youtube.com/watch?v=S_mbKtDD30o
http://www.youtube.com/watch?v=o9Cxknv3CME
http://www.youtube.com/watch?v=WFF2O4NqOpo
Central mikrotik’s config :
> /ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0 X ;;; default configuration
     192.168.88.1/24    192.168.88.0    192.168.88.255  ether2-local-master
 1   82.35.120.247/24   82.35.120.0     82.35.120.255   ether2-local-master
 2   192.168.85.1/24    192.168.85.0    192.168.85.255  ether3
 3 X 82.35.120.248/24   82.35.120.0     82.35.120.255   ether5-local-slave
 4   82.35.29.58/30     82.35.29.56     82.35.29.59     ether1-gateway
 5   72.111.61.145/28   72.111.61.144   72.111.61.159   ether5-local-slave
 6 D 192.168.85.1/32    192.168.26.1    0.0.0.0         user-pptp-server
 7 D 192.168.85.1/32    192.168.26.1    0.0.0.0         <pptp-userauth>
 8 D 192.168.85.1/32    192.168.26.1    0.0.0.0         <pptp-userauth-1>
 9 D 192.168.85.1/32    192.168.26.1    0.0.0.0         <pptp-userauth-2>
10 D 192.168.85.1/32    192.168.26.1    0.0.0.0         <pptp-userauth-3>
11 D 192.168.85.1/32    192.168.26.1    0.0.0.0         <pptp-userauth-4>
> /interface eoip print
 0  R name="eoip-tunnel-imes" mtu=1500 l2mtu=65535 mac-address=02:54:BD:E7:D1:9B arp=enabled
      remote-address=192.168.26.1 tunnel-id=1
> /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE                       BRIDGE                      PRIORITY PATH-COST  HORIZON
 0    eoip-tunnel1	              bridge1                     0x80     10         none
 1    ether3                          bridge1                     0x80     10         none
> /ip firewall export
# jan/18/1970 10:17:58 by RouterOS 4.11
# software id = H1T1-SS5H
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
    tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s \
    tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=\
    ether1-gateway
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
> /ip route export
# jan/18/1970 10:22:24 by RouterOS 4.11
add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    82.35.29.57 scope=30 target-scope=10
add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=82.35.120.1 scope=30 \
    target-scope=10
Remote Location’s Config :
> /ip address print
 0   85.10.147.120/24   85.10.147.0     85.10.147.255   ether2-local-master
 1   10.0.5.1/24        10.0.5.0        10.0.5.255      ether5
 2   192.168.26.1/24    192.168.26.0    192.168.26.255  ether4
 3 D 192.168.26.1/32    192.168.85.1    0.0.0.0         pptp-out1
 0  R name="eoip-tunnel1" mtu=1500 l2mtu=65535 mac-address=02:8B:FB:5B:CE:59 arp=enabled
      remote-address=192.168.85.1 tunnel-id=1
 1 I  ether4                                   bridge1                               0x80     10         none
> /ip firewall export
# jan/05/1970 06:57:32 by RouterOS 4.11
# software id = 3T2W-87NW
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s \
    tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
add action=masquerade chain=srcnat comment="" disabled=no out-interface=ether2-local-master
set sip disabled=yes ports=5060,5061
> /ip route export
# jan/05/1970 07:04:33 by RouterOS 4.11
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=85.10.147.1 scope=30 target-scope=10
add comment="" disabled=yes distance=1 dst-address=192.168.26.0/24 gateway=192.168.85.1 scope=30 target-scope=10
bump!
Any idea ?
