I had to modify is methods to get the VLAN filtering to work the AX2 and AX3, so not surprised there are better ways to implement things. Can you point me to directions on how to do this?
Okay you need to let me know the purpose of each port on the hapax3. To what it leads to, and to what vlan the connected device belongs to.
Remember access between vlans and to their devices is controlled by the firewall rules on the 5009
But first, … as stated above…
ether1 connects to RB5009
ether2 I want as dedicated management port (This is what I don’t know how to do when in switch/AP mode)
ether3-5 connect to PCs and Printers.
Ether3, which subnet???
Ether4, which subnet???
Ether4 which subnet???
Ether5- will add an offbridge subnet for your local access, the ap/switch MT, will be accessible also from the management or trusted subnet it gets its IP from.
(1) Added home vlan, so bridge does nothing but bridging and you were missing vlan10 items like dhcp-server and pool !!
(2) Ether2, will be a management port
(3) Ether6, will be an oFF bridge port ( ability for you as admin to access or config router Off the bridge ( safest way to config ).
(4) Quotes are not complete in /interface bridge vlans, each 7/8 interface needs both quote marks. Also you put quote around the bridge interface .......
(5) Is UPNP necessary???
(6) if you want to use the5009 to be an NTP time server for devices on the LAN, then it needs to be a client to a source as well!!!
HAPAX3 NOTE this is a non capsman config as I have no clue how to do capsman, too complicated for me. Any vlans / data path removed from wifi settings. You should appreciate how uncluttered and quick this is to configure once the 5009 is done.
(1) Will assume etherports 3,4,5 are for home wired network, otherwise they should not be identified on the bridge.
(2) Better to use ether2 for off bridge access as its already accessible on management vlan from the 5009, better to have a local off bridge safe method.
(3) Assuming Bar2G is for guest or IOT, and Bar5G is for home use.
model = C53UiG+5HPaxD2HPaxD
set [ find default-name=ether2 ] name=ether2-OffBridge
