I am new user of hap lite and I have one problem and so far I can’t find the solution how I can fix it.My router is connected to modem(which is on bridge mode) with pppoe protokol.This is working fine but from modem I have another cable for iptv and now I have This cable like is in this picture.I can look tv and also I have internet on ethernet3-slave port but the problem is that the internet is somehow messed up.The speed is going down and up.Can you guys help me how I can setup router that will work correct and not slow down wifi or other local ports but I need internet and video signal on ethernet3-slave port?
I will ask another way and I hope someone can help me.Is it posible to routed all traffic from ether2-master-local port to only ether3-slave-local port and how I can do this?
Unfortunately, I don’t think anyone understands what you are trying to do.
Mikrotik routers are extremely flexible and can likely do exactly what you need, but you will need to explain what it is that you want so what we can understand it.
To start with, I don’t understand why you have two cables connecting the modem to the router.
Your ISP modem/router has 1 eth port for internet, lets say LAN1.
LAN2 port is for IPTV.
Now you wan to connect MT to your ISP modem/router and then connect your devices to MT?
What do you need to provide is:
*How your ISP is routing you to internet?Access technology ( xDSL, Fiber…) and how you are obitaining WAN IP?
*How your ISP is delivering IPTV to you? ( VLAN, Bridging per PVC,etc etc)
*Do you even really need IPTV to be connected to MT?
Thank you to try to understand my config!Yes I know that is hard to understand and my english is not so good but I will try to explane.
yes you are right!
I have FTTH optik connection with dynamic IP address.My ISP provider delivering IPTV through vlan ,so I have tvbox from my ISP provider to watch tv but this box is really slow so I have setup satelite box VuZero to watch also IPTV channels and It’s faster and I can made my own channels list.The setup from my picture works but I have problem with wifi becouse the speed is really slow when someone watch TV.maybe will be enough to block IPTV to wifi from ether3-lan port but I don’t know how.
Yes I need that IPTV to be connected to MT because only in this way I can have internet and IPTV on same port.I hope you can understand what I mean
Whats with your CPE usage on HAP while you are streaming and surfing at same time?
Also, are there multicast issues(flood) on local-bridge?
Can you post your config export?
If I am connected wired to MK there is no problem with the internet speed,so I think no issues with flood,only on
config.txt
wifi.The cpu usage is max 28% while I look tv on hd channel.Here is my compact config.
sorry for late reply.
Because you have connected your IPTV VLAN to bridge interface ( where are all of your devices, and multicast traffic is flowing), there can be some issues with multicast helper running on AP. Try to disable it.
In the mean time I am already disable multicast helper but not much better.Interesting that lan work just fine If I look TV or not the speed is the same only the wifi speed is going down when I look tv.If I turn of IPTV the speed is the same like on LAN.
Today I am upgrade to 6.31rc11 version and wifi speed is much better,now I only need to know how I can set MK so the multicast will not effect wifi.
