I need some help - which one to buy
Hi all, i need some help in choosing the right router for my setup:
I was trying to make it as clear as i can :slight_smile:
Basically the router needs to have SIM Card port and some WAN and LAN ports.
I will really appreciate your help.
What about
https://mikrotik.com/product/rbm33g
https://mikrotik.com/product/CA433U
https://mikrotik.com/product/r11e_lte
Thank you very much for reply. Any chance you could recomend something that fits in 19’ rack? (i mean with rack mounts)
Built-in LTE modem kind of contradicts placement in (metal) 19" rack. Even if you happen to find such device I wouldn’t recommend using it. Unless you happen to have either base station or signal booster installed right next to the rack.
Possible work-around would be to use external LTE antennae to bring the LTE signal in … beware that cable loss is not neglectable and it is generally advised not to use antenna cables longer than 5-10 metres (if they are low loss that is).
