I need to configure 120 routerboards 450G with same config..
I need to configure 120 routerboards 450G with same configuration. How can I clone or copy exactly ALL configuration including users and passwords easily?
Configuring all routers manually will take several time.
I’ll appreciate your support!
This should do a lot of what you want: http://wiki.mikrotik.com/wiki/Milliscript
Agree, but make sure that all units are running same ROS version and same F/w since not all commands are the same across v4 and v5.
I would also look at FlashFig - this might be quicker - http://wiki.mikrotik.com/wiki/Flashfig
Rgds,
Mark.
Thanks a lot for your help.
I’ll try to use it. Flashing is part of NetInstall or is independent application?
Regards
Did you not read the wiki link from the post above???
“Flashfig runs on a Windows computer, Flashfig is available within Netinstall.”
