Hi all,
I want to ask you, if it is possible to someway deactivate creating dynamic IP address in address list.
I use a openVPN tunnel and I use for it IP addresses with 30 bit mask.
On client ( ovpn ) Mikrotik create some IP with 30 bit mask ( according to server setting ) - this is OK,
but on ovpn server is the IP without mask ( it means 32 bit mask ).
Data are running via this tunnel, but I use OSPF there. Here is than the problem with OSPF assignment.
LOG: " Discarding Hello packet - mismatch in network mask "
On Mikrotik ( ovpn server ) I have create fixed IP with 30 bit mask, but if the Inet line goes down and up again,
Mikrotik create the some IP address ( dynamic ) but with 32 bit mask. Then I have to delete this dynamic IP and OSPF is running again.
So that simply: I need to forbid generating some dynamic IP.
It is possible?
Thank You very much!
Libor
