i small issue with Ntype connections
Morning
I’ve having a small issue when it comes to the N type cards
First off on my AP, i have had to set the AP frequency to 5GHZ, it is the only one that will work, everytime i set it to any other 5Ghz frequency in this (5Ghz only N being the one i’m after) nothing will pick up the antenna
The other issue i’m having is only N type cards or 7 series boards pick up this AP :confused:
i can’t figure out what it is that i’m doing wrong
right, as for details, i’m not sure what you would like me to show you so just tell me what i should print out here and i’ll do so
