I sometimes face this ‘PPPoE status Terminating… -failed to authenticate ourselves to peer.’ while connected to the router wirelessly. Then, I log in to the Winbox, and disconnected, and reconnect again to PPPoE. (sometimes I had to unplug and plug the router) But it took a certain time to reconnect again when I reconnected to PPPoE via WinBox.
Although the Mikro Tik router and Modem(TP-Link in bride mode) have NOT been unplugged, I don’t know what might be causing the problem. I don 't if the problem is with the Mikro Tik router or not.
This problem ‘Terminating the PPPoE…’ is very bad since if I am watching a video on Youtube, then when this problem happens, the internet access got disconnected, and then I will need to reload the webpages from the beginning.
When I logged in to the Winbox, and then tried reconnecting again many times, then I succeeded to reconnect again.
there is no telling or exact time when this error shows up, happens 3-4 time in 1h then works fine for few hours, or less
most of time when i’m playing so it results in disconnecting from servers and that’s very annoying
could it be related to any config in Router? IP,Firewall,…
