I suffer strongly from scammers and hacker
I suffer severely stolen MAC addresses customers as well as I suffer from the fraud exceeded the login page By xboxs
I saw this problem:And tried it myself through my phone Android there is a program that looks for MAC addresses connected to the network and other program changes the name changemac, Mac telephone to any other Mac
I expected to see:You solution very fast Please networks crumble about three weeks, a position so I bought a license level i because I think that these problems are not found in it
Steps to repeat this issue: I have frequently too many crooks on the web outwitted me by all means I hope you give the roll or a solution very quickly please
Arabic language and I am not good at so you put pictures illustrative of one type of species faced by networks
I’ve got a network is very simple, but I suffer from scammers and stolen online and needed a wall strong protection and I need someone to help me in so I’m Mbtdae I do not have experience enough if here someone can help me I should be grateful to him and ready payment to him if he wants the amount vs
my phone 00967770323466
my emil alakwaa_mohammed@yahoo.com
Use WPA2 security. Then only those devices that knows the key can log into your network.
If you provide internet access publicly, use hotspot for user authentication and do not allow internet access for unauthenticated users.
Thank you very much for you the only one who tried to help me and answer
But did not understand you well
Did you mean to do my work password for ACCESS POINT
This does not work with me because the networks operate Pre Order and customers are not limited or known I hope you understand what I mean
I am Arabic language is not good with me
Image is attached to form a comprehensive picture of your private network
Information about the network settings + What kind of why I want to help or required of you my friends valued
Tools that are used by the
!: Win Box
A: USER manager
Is not
As for the settings used in the system
They Hotspot + Radius + queues + DHCP
What is required, or What I want you to help dear type
Is to improve the network settings and security settings are where I make full penetration of the network and also
Online stolen by repeating MAC address and also search for Mac connected by optical scanners
And many types of fraud
Well, I can not prevent from the Internet broadcast by Sawa client connected to the network via Bluetooth or GPRS transmission
So I hope you can help me in safe settings be thankful to you
200 scenes and there is no response or an attempt to help me why so
Is it because I’m Arabic or what
None cares who you are or where are you from. Maybe you didn’t describe your problem in the way others can understand.
No one answers because this is something that has come up several times on this forum and the answer remains the same today as it was then. You need to lock down your layer2 network in such a way as to prevent layer 2 communications between people that connect to the network. Simply put, a router can only control the traffic that flows across it, it has no way of seeing or controlling what a client does on the edge of the network.
What this means is disable default forward on Mikrotik wireless cards, or enable client isolation on other vendors access points. For switches, this means enable the port isolation feature, or use VLANs. This is how you properly prevent people from receiving broadcast packets across the layer2 network, or scanning the layer2 portion of your network and seeing active MAC addresses. If you don’t have hardware that supports this, then invest in it. However, setting these things up won’t prevent someone from generating a random MAC address, once again, you cannot control what an end user does to their device.
v6 hlooooooooooooooooooooooo
