I am using Mikrotik netmetal 921 with 30 dbi mimo dish. My connicitivit is on -55/-56 distance 5 k.m. I want minimum 120 Mbps but i m getting only 70 to 80 Mbps. Please suggest me what I have to do
With 40MHz channel width and 1 data stream you won’t get 100Mbit of actual user data rate out of that 801.11ac P2P link.
Can you go for 80MHz channel width? Should put you 140-160Mbit @ 1 data stream in your constellation.
