I want help in script sends ip router dsl via email with com
I want help in script sends ip router dsl via email with commentary
:confused:
if you are from egypt i can help you :smiley:
this is the script to send wan ip to gmail
/system script
add name=send-wan-ip policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api source="/tool fet\
    ch url=\"http://mikrotik.vv.si/getip.php\" mode=http dst-path=wan-ip.txt\r\
    \nlocal ip [file get wan-ip.txt contents ]\r\
    \nput \$ip\r\
    \n:delay 10s\r\
    \n/tool e-mail send server=173.194.66.108 port=587 tls=yes user=\"Gmail user name\" passwo\
    rd=\"Your PassWord\" from=\"Your Email\" to=\"Your Email\" sub\
    ject=(\" wan-ip By:Eng / Mostafa Mohamed _ \" . [/system clock get date] . \" - \" . [/system clock get time])  \
    file=wan-ip.txt\r\
    \n\r\
    \n:log info \"wan-ip sent  :)\""
/system scheduler
add comment="send wan ip to gmail every 1 h  by Mostafa Mohamed" disabled=no interval=1h name=send-wan-ip on-event=send-wan-ip \
    policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api start-time=startup
