I want save backup to sub folder
why this script dos not work??
:local name  [/system/identity get name]
system/backup/save name=aaa/$name
system/backup/save name="disk/backup/$name"
Still not work if the user not create directories first…
thanks
CLI
tool fetch address=ftp src-path="export/$name" user=imirsay@kooshkoo.iapp.ir mode=ftp password=00 dst-path="directory/subfolder/$name" upload=yes
Note: It’s recommended that use SFTP if the transfer is over a public network.
thank you so much
I want remove user in usermanager if dont active profile and uptime not zero. Can you help?
