I have Mikrotik with hotspot. I used every method I find to stop netcut but unauthorized users can get IP and MAC address of an authorized user and set their wireless adapter and they use the internet without passing with the login page
In hotspot, it appear that one user is login, but two users are sharing the connection.
what is the solution?
Note:
the hotspot Ethernet port connected to switch which is connected to APs
Impossible to solve on the Hotspot. Buy switches and APs that can perform client isolation and disconnect wireless and wired clients when they detect spoofing. Note that legitimate clients may flap between APs and cause false positives unless a system performs some very advanced analysis.
In short, there is no magic button for this that doesn’t cost a lot of money (tens of thousands of dollars).
It is only useful to set the netmask to /30 if you have a DHCP server that can give each client its own gateway. RouterOS cannot do that. Additionally, it doesn’t prevent anyone accessing the network via wireless from spoofing a MAC and IP address, so it is useless for your purpose (it can be useful on the wire in some situations). Same for /32, which will not work at all on a non PPP network. Such a static ARP entry doesn’t help, either.
It’s not want you want to hear, but: there is no solution for netcut (or whatever other name you want to give someone finding a legitimate MAC and IP address combination and spoofing it) for you to implement. So it goes.
