I want to close all websites except for specific sites
Hi
can you help me
can you help me
Probably not.
You can easily allow access to IP address of your websites and block the rest. You can even work with hostnames, just put them in address list and RouterOS will resolve them to IP addresses automatically, then you can use this address list as rule condition. But it will only work reliably if those websites are completely self-contained, i.e. they don’t load resources from elsewhere. If they do (and that’s true for most websites nowadays), they won’t work correctly, more or less, depending on what exact resources they load (and won’t be able to when you block them). But once you start to whitelist those too, it will be a never ending story and you’ll soon find out that you allowed much more than you wanted.
one way, maybe.
configure your PC’s DNS, so the website you try to allow is pointed to the Mikrotik,on which you set up a Proxy, then forward traffic to the internet
configure Mikrotik you drop all request on port 80, port 443, port 8080 etc. this stops anyother web access.
think of if, block VPN ports as well :laughing:
