Hi All,
Please can you help with this, I want to increase my bandwidth by bonding 2xwlan interfaces to behave as one. I am currently only able to get 32MB on 1xwlan link. My ISP is 10km away, my signal strength is -75dB(stable) on both links, I have 1xPublic IP that i need to use across both links.
I have managed to get the below config, which does not seem to be working… am i missing something vital in the config. I have carried it out to the last dot.
PS: i have altered the IP address to suite my networ ofcourse..
Here is a step-by-step explanation how to enable nstreme dual on a fresh installed MikroTik devices:
I. MikroTik Device 1
1.1. Enabling wireless cards 1 and 2:
[admin@MikroTik] > interface enable wlan1
[admin@MikroTik] > interface enable wlan2
1.2. Assigning IP address to the ethernet interface:
[admin@MikroTik] > ip address add address=192.168.1.1/24 interface=ether1
1.3. Creating bridge interface:
[admin@MikroTik] > interface bridge add
1.4. Adding ethernet interface to the bridge interface:
[admin@MikroTik] > interface bridge port add interface=ether1 bridge=bridge1
1.5. Setting wireless cards 1 and 2 to nstreme mode:
[admin@MikroTik] > interface wireless set wlan1 mode=nstreme-dual-slave
[admin@MikroTik] > interface wireless set wlan2 mode=nstreme-dual-slave
1.6. Creating nstreme dual interface and setting Tx and Rx radios and frequencies:
[admin@MikroTik] > interface wireless nstreme-dual add rx-radio=wlan1 tx-radio=wlan2
rx-band=5ghz tx-band=5ghz rx-frequency=5180 tx-frequency=5300
1.7. Adding nstreme interface to the bridge:
[admin@MikroTik] > interface bridge port add interface=nstreme1 bridge=bridge1
1.8. Checking the MAC address of the nstreme interface (in this example: 11:11:11:11:11:11):
[admin@MikroTik] > interface wireless nstremedual print
Flags: X disabled, R running
0 X name=“nstreme1” mtu=1500 macaddress=11:11:11:11:11:11 arp=enabled
disablerunningcheck=no tx-radio=wlan2 rx-radio=wlan1 remotemac=00:00:00:00:00:00
tx-band=5ghz tx-frequency=5300 rx-band=5ghz rx-frequency=5180
ratesb=1Mbps,2Mbps,5.5Mbps,11Mbps
ratesa/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
framerpolicy=none framerlimit=2560
II. MikroTik Device 2
2.1. Enabling wireless cards 1 and 2:
2.2. Assigning IP address to the ethernet interface:
[admin@MikroTik] > ip address add address=192.168.1.2/24 interface=ether1
2.3. Creating bridge interface:
2.4. Adding ethernet interface to the bridge interface:
2.5. Setting wireless cards 1 and 2 to nstreme mode:
2.6. Creating Nstreme dual interface and setting Tx and Rx radios and frequencies and setting the MAC address of the remote nstreme interface (in this example: 11:11:11:11:11:11 [step 1.8]):
rx-band=5ghz tx-band=5ghz rx-frequency=5300 tx-frequency=5180
remotemac=11:11:11:11:11:11 disabled=no
2.7. Adding nstreme interface to the bridge:
2.8. Checking the MAC address of the nstreme interface (in this example: 22:22:22:22:22:22):
0 R name=“nstreme1” mtu=1500 macaddress=22:22:22:22:22:22 arp=enabled
disablerunningcheck=no tx-radio=wlan2 rx-radio=wlan1 remotemac=11:11:11:11:11:11
tx-band=5ghz tx-frequency=5180 rx-band=5ghz rx-frequency=5300
III. MikroTik Device 1
1.9. Setting the MAC address of the remote nstreme interface (in this example: 22:22:22:22:22:22 [step 2.8]):
[admin@MikroTik] > interface wireless nstreme-dual set nstreme1
remotemac=22:22:22:22:22:22 disabled=no
