i want to port forward
Hello
I am BasilSaeed
And i want to portforward a Counter Strick 1.6 server
I have Zero knowledge ( Will i can port forward with normal router which are not having crazy amount of options , the one with Open port , end port , ip , protocol . The one which have this option )
So all i know i go in the Firewall then in NAT then I see then press add
Then i see BILLIONS of options
so thats makes me go crazy
the port i want to forward to is 27015 ( UPD )
and the ip ( my computers ) is 192.168.1.16 ( hosting the server on my computer )
I have a net that has a Static IP ( cant give because can get ddosed if some one wants to )
I have attached two pictures
Please check them and tell me what to write in what field to port foward with the following IP
( Also i request you people to add a easy way to do this )
Hey. Just use dstnat chain with dst-nat action.
Dst address - your Internet IP address(or you can choose “in interface” without IP address)
Protocol - UDP
Dst port - 27015
Chain - dstnat
Action - dst-nat to address 192.168.1.16 to ports - 27015.
Thats it :slight_smile:
In order to forward this traffic through firewall you will need nothing but standart firewall rules.
