/file print file=Log.txt;
:delay 2;
/file set Log.txt contents="";
# Array to store all speed test results
:local results "";
:for i from=1 to=3 do={
/interface pppoe-client enable ("pppoe-out".$i);
/interface pppoe-client set ("pppoe-out".$i) comment="Waiting for results...";
:delay 5;
:local txAvg 0;
/tool bandwidth-test 111.222.333.444 duration=5s direction=transmit protocol=tcp user=admin do={
:set txAvg ($"tx-10-second-average"/1000);
:local currentComment [/interface pppoe-client get ("pppoe-out".$i) password];
:local newComment ($currentComment." | Upload: ".($txAvg / 1000)." Mbps");
/interface pppoe-client set ("pppoe-out".$i) comment=$newComment;
:if ([:len $results] > 0) do={
:set results ($results . "\n" . $newComment);
} else={
:set results $newComment;
/interface pppoe-client disable ("pppoe-out".$i);
# Sort results by speed in descending order
:local sortedResults "";
:log info "Starting sorting process.";
# Debug: Print the content of results before sorting
:log info ("Results before sorting: ".$results);
:local lines [:toarray $results];
:log info ("Total lines to sort: ". [:len $lines]);
# Debug: Print the lines array to verify splitting
:local linesDebug "";
:foreach line in=$lines do={
:set linesDebug ($linesDebug . ", " . $line);
:log info ("Lines array: " . [:pick $linesDebug 2 [:len $linesDebug]]);
:if ([:len $line] > 0) do={
:local speed 0;
:local uploadPos [:find $line "Upload: "];
:local mbpsPos [:find $line " Mbps"];
:log info ("Found 'Upload: ' at position: ".$uploadPos.", 'Mbps' at position: ".$mbpsPos);
# Extract speed value
:if (($uploadPos != nil) && ($mbpsPos != nil) && ($mbpsPos > $uploadPos)) do={
:local speedStr [:pick $line ($uploadPos + 8) $mbpsPos];
:set speed [:tonum $speedStr];
:log info ("Extracted speed value: ".$speedStr." Mbps (converted to number: ".$speed.")");
# Insertion sort logic
:local inserted false;
:local tempResults [:toarray $sortedResults];
:local newSortedResults "";
:foreach sortedLine in=$tempResults do={
:if ([:len $sortedLine] > 0) do={
:local sortedSpeed 0;
:local sortedUploadPos [:find $sortedLine "Upload: "];
:local sortedMbpsPos [:find $sortedLine " Mbps"];
# Extract speed value from sorted line
:if (($sortedUploadPos != nil) && ($sortedMbpsPos != nil) && ($sortedMbpsPos > $sortedUploadPos)) do={
:local sortedSpeedStr [:pick $sortedLine ($sortedUploadPos + 8) $sortedMbpsPos];
:set sortedSpeed [:tonum $sortedSpeedStr];
# If current speed is greater than sorted speed and not inserted, insert current line
:if ($speed > $sortedSpeed && !$inserted) do={
:set newSortedResults ($newSortedResults . "\n" . $line);
:set inserted true;
:log info ("Inserted line: ".$line." (speed: ".$speed." Mbps) into sorted results.");
# Add sorted line
:set newSortedResults ($newSortedResults . "\n" . $sortedLine);
# If not inserted, append current line to the end
:if (!$inserted) do={
:if ([:len $newSortedResults] > 0) do={
} else={
:set newSortedResults $line;
:log info ("Appended line: ".$line." (speed: ".$speed." Mbps) to the end of sorted results.");
# Update sorted results
:set sortedResults $newSortedResults;
:log info ("Updated sorted results: ".$sortedResults);
/file set Log.txt contents=$sortedResults;
The above code was generated by combining AI and modified by oneself, but the result still cannot be sorted properly. Please consult the expert~The result of the program running is:
2310138 | Upload: 32 Mbps
2310517 | Upload: 48 Mbps
2226923 | Upload: 81 Mbps
And the result I want is:
The ROS version I am using is 6.49.18. Can’t version 6. x perform such complex operations?
