i want to upload 2.3ghz frequency can it possible
sir i want to upload 2.3ghz frequency in my MT
in b/g band what is the procedure.
set the frequency-mode to regulatory-domain and then set the country to your country and you will be able to use all frequencies that are allowed in your country.
Are you from INDIA ? , If you are in INDIA it is impossible to use that frequency.check your country regulatory domain as per normis statement.
