I want to use the LACP to speed up my internal network.
However, when i connect the network from Windows 10 to teaming, the speed drops by half.
Do I need to set anything separate from switch control tools?
On the LAG tab, the mode of the port in use changed from passive to static.
And then there was an IP conflict and the Internet didn’t work.
So I put it back into passive mode.
What exactly can I do to double my Internet speed?
With SWOS I left it for impossible. With RouterOS v6.42.6 it works fine, although there seems to be a bug with the VLAN tags if vlan_filtgering is not on YES
I recomend you use RouterOS or wait for more stable SWOS
