I have a problem
I have wireless network
and have pppoe connect so the customers can enter through dial up
but right now theres is a problem that customer can have internet with or without dial up
what to do
what setup change it
thanks
Don’t assign an IP address to the PPPoE interface!
Or make firewall rule in forward chain to drop all traffic from DHCP assigned pool of addresses.
Thanks for fast reply
but
please,I want more than that
I want to tell me from where I can change this setup firewall or other
I afraid do other wronge steps and get down whole network
Using winbox - goto a Terminal window and press ctrl-x this will put you in safe mode, if you break the router it will roll back the config to before ctrl-x
as ofasa said remove the IP address from the PPPoE interface, then only people who use PPPoE will get a connection.
Once you are OK with your router changes go back to the terminal window and press ctrl-x again to commit your config.
For more help you must post your config for interfaces, IP addresses, firewall rules etc.
Hi Hussain, I´trying to configure a MTK routerboard with the same congi.
Colud you pls send me your config?
I failed with great succesfull.
I can´t be the wirelees lan to run.
my e-mail if you want to send me directly, is:
Thanks in advance
Fernando
I will help you as much as I can
just tell me what you want
or what problem you faced
