How do I set up the Modiom in RouterOS 3.22 by USB
I do not want to use the network port(ether), I want use the USB port !!! But how do I do this?!
/port print
I using pppoe
How can i get internet by using USB port
what device have you connected to the USB port?
Dynalink - ADSL2+ Modem Router
http://www.dynalink.co.nz/cms/index.php?page=adsl2-modem-router-rta1320
any help pleas!!!
normis wher anser ???
a DSL modem? and what did you expect to happen?
DSL modem is supposed to be connected to the Ethernet port. For USB port the only devices that are supported are 3G wireless cards
i use 2 usb ports for Network cards. and working perfect !
they work from when i installed my ros 2.9.41 untill now 3.22
i was thinking of putting a wireless card using usb
does any one know a compatible one (USB!!!) ??
As I said, they won’t work. RouterOS supports only 3G cards, and very few Ethernet cards. Otherwise, you can only use USB for connecting Storage devices.
Hi which USB network cards are you using ?
