i wont 1 more adsl to my hotspot...
Hello all.
I have a hotspot but but my users are too many so i need a second adsl line.my problem is that i do not know how to configure my hotspot if it exceed the 10 clients per time to use the second adsl line
Adsl 1 isp router: 192.168.1.1
Adsl 2 isp router: 192.168.10.1
Mikrotik isp1 interface: 192.168.1.111
Mikrotik isp2 interface: 192.168.10.2
Mikrotik dhcp, hotspot: 192.168.2.1
thanks
nothing?
Might be easier if you can find a DSL provider that supports MLPPP and simply bond the two (or more) DSL connections? Works very well on the RouterBoards…
The only other way would be load balancing the two DSL connections using Policy Routing:
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
-zeb
Use bandwidth based load balancing.
Sent from my MI MAX using Tapatalk
