iam have 6.47.8 (stable) on x86 but some time its shutdown suddenly
iam have 6.47.8 (stable) on x86 but some time its shutdown suddenly on asxi
just only mikrotik shutdown with no massage from esxi and mikrotik system
it big problem
What exactly is asxi? Or do you mean ESXi (VMware)?
Having a hole in ROS graph does not prove router was actually shut down. So if it was actually shut down (you had to restart it manually) and there’s nothing in ROS logs nor anything in logs of hypervisor, then you’ll have some long days troubleshooting. If you suspect that there was actually a reboot of ROS, you can verify actual uptime by running command /system resource print. If uptime recorded doesn’t correspond with hole in the graph, then graph is not to be trusted. If uptime does correspond with hole in the graph, then you’ll have some long days troubleshooting.
yaa ESXi
iam confused
in esxi no error was found
iam installed before 1 year and every things work normally
this problem has 3 month
iam have 4 VMware on ESXi
but just Mikrotik system shutdown and iam turn on manually
look its between 18 and 20
Check disable WatchDog, same problem have.
