I am trying to get setup a mikrotik router to accepted incoming IAX2 connections UDP 4569 for a DID.
if I remove the router the incoming calls work fine, but when I try and setup the router using standard src rules it doesn’t work. ![]()
Any help with this would be more than welcome
Thank you.
