Hi Guys,
I have a problem to establish an new ibgp - session. Router 1 (R1) has an external working ebgp-session, also on router 2 (R2). To get redundancy I will setup an internal bgp-session. The connection between R1 and R2 was a DAC-cable und ping works well. The network between R1 and R2 is /31, but testing with a /30 has the same issue.
bgp-config on R1:
name=“ibgp_1”
remote.address=x.y.z.231/32 .as=214000
local.address=x.y.z.230 .role=ibgp
tcp-md5-key=“1xxxxxxx9” connect=yes listen=yes routing-table=main as=214000 nexthop-choice=force-self address-families=ip
output.redistribute=connected .default-originate=if-installed
bgp-config on R2:
name=“ibgp_1”
remote.address=x.y.z.230/32 .as=214000
local.address=x.y.z.231 .role=ibgp
In torch I see on both router packets to port 179.
Have anyone an idea to fix the problem?
Best regards
Rheinhesse
