I tried to make a simple route reflector setup with three routers (CHR 7.1.1). I tried several setups to no avail. Since the documentation is a kind of sparse on this subject I tried to Goolge it, read iBGP rr documents etc… The only advantage, for now, is that my understanding is a bit better, but there is stil a lot to learn.
Can someone point out the error I made and why…
R01 is the client.
R02 is the RR.
R03 is the client.
R01
# jan/06/2022 19:08:02 by RouterOS 7.1.1
add name=Loopback01
set [ find default-name=ether1 ] disable-running-check=no name=Eth01
set [ find default-name=ether2 ] disable-running-check=no name=Eth02
set [ find default-name=ether3 ] disable-running-check=no name=Eth03
set [ find default-name=ether4 ] disable-running-check=no name=Eth04
set [ find default-name=ether5 ] disable-running-check=no name=Eth05
/routing id
add disabled=no id=172.16.0.1 name=RouterID select-dynamic-id=only-vrf select-from-vrf=main
/routing ospf instance
add name=OSPFInstance router-id=RouterID
/routing ospf area
add instance=OSPFInstance name=OSPFArea
add address=192.168.100.101/24 interface=Eth05 network=192.168.100.0
add address=172.16.0.1 interface=Loopback01 network=172.16.0.1
add address=10.1.2.1/24 interface=Eth01 network=10.1.2.0
add address=10.1.4.1/24 interface=Eth02 network=10.1.4.0
/ip firewall address-list
add address=10.1.2.0/24 list=BGP
add address=10.1.4.0/24 list=BGP
add address=172.16.0.1 list=BGP
/routing bgp connection
add as=70000 cluster-id=172.16.0.2 disabled=no local.address=172.16.0.1 .role=ibgp-rr-client name="R01 - R02" output.network=BGP .no-client-to-client-reflection=yes remote.address=172.16.0.2/32 .as=70000 router-id=172.16.0.1 routing-table=main vrf=main
/routing ospf interface-template
add area=OSPFArea networks=10.1.2.0/24,10.1.4.0/24,172.16.0.1/32
/system identity
set name=R01
R02
# jan/06/2022 19:06:16 by RouterOS 7.1.1
add name=Loopback01
/routing id
add disabled=no name=172.16.0.2 select-dynamic-id=only-vrf select-from-vrf=main
add name=OSPFInstance router-id=172.16.0.2
/routing ospf area
add address=192.168.100.102/24 interface=Eth05 network=192.168.100.0
add address=172.16.0.2 interface=Loopback01 network=172.16.0.2
add address=10.1.2.2/24 interface=Eth01 network=10.1.2.0
add address=10.2.5.2/24 interface=Eth03 network=10.2.5.0
add address=10.2.3.2/24 interface=Eth02 network=10.2.3.0
add address=10.2.3.0/24 list=BGP
add address=10.2.5.0/24 list=BGP
add address=172.16.0.2 list=BGP
add as=70000 cluster-id=172.16.0.2 disabled=no local.address=172.16.0.2 .role=ibgp-rr name="R01 - R02" output.network=BGP .no-client-to-client-reflection=no remote.address=172.16.0.1/32 .as=70000 router-id=172.16.0.2 routing-table=main vrf=main
add as=70000 cluster-id=172.16.0.2 disabled=no local.address=172.16.0.2 .role=ibgp-rr name="R02 - R03" output.network=BGP .no-client-to-client-reflection=no remote.address=172.16.0.3/32 .as=70000 router-id=172.16.0.2 routing-table=main vrf=main
add area=OSPFArea networks=10.1.2.0/24,10.2.3.0/24,10.2.5.0/24,172.16.0.2/32
/system identity
set name=R02
R03
# jan/06/2022 19:07:14 by RouterOS 7.1.1
add name=Loopback01
/routing id
add disabled=no id=172.16.0.3 name=RouterID select-dynamic-id=only-vrf select-from-vrf=main
/routing ospf area
add address=192.168.100.103/24 interface=Eth05 network=192.168.100.0
add address=172.16.0.3 interface=Loopback01 network=172.16.0.3
add address=10.2.3.3/24 interface=Eth02 network=10.2.3.0
add address=10.3.6.3/24 interface=Eth01 network=10.3.6.0
add address=10.3.6.0/24 list=BGP
add address=172.16.0.3 list=BGP
add as=70000 cluster-id=172.16.0.2 disabled=no local.address=172.16.0.3 .role=ibgp-rr-client name="R02 - R03" output.network=BGP .no-client-to-client-reflection=yes remote.address=172.16.0.2/32 .as=70000 router-id=172.16.0.3 routing-table=main vrf=main
add area=OSPFArea networks=172.16.0.3/32,10.2.3.0/24,10.3.6.0/24
/system identity
set name=R03
