So i have a few wireless AP’s that i want to do some testing with. I’m very new to mikrotik systems but the 10GB wired router i have is pretty awesome so far.
I have 2 AP’s which are 2 separate SSID’s that i want to have 2 devices connect to as a client/bridge where i can then use the router to do link aggregation/bandwidth management through the wired connection to the wireless client/bridge to use different pipes when they reach the threshold.
I can configure this on the router no issues however mikrotik hardware is nothing i am very knowledgeable about.
What devices would best fit my use case? I don’t need anything fancy just something gig wired and N capable wireless. The lower the power usage the better.
This device would work for what i want to do correct? https://mikrotik.com/product/RB952Ui-5ac2nD
