Ideal wireless setting for p2mp network
Hi, I am newbie and want to understand MT wireless.
I have seen lot of posts and getting confused.
Can anyone tell me what should be ideal setting for a p2mp link
Range- 5 kms
5 GHz.
Need following details.
  1. Main Link- Mode :AP- Bridge. Is any other mode supported? I want use nstream
    Main Link is Omnitik. Only one Omnitik on tower
  2. On Clients. Mode : Bridge [ I want pppoe with pppoe server which is connected with Main Link ], Can I use any other mode?
    station? station-bridge? station-pseudo-bridge?
  3. Main Link: Channel Width? Should I keep 5mhz?
  4. Channel : Should I use supperchannel?
  5. Wireless Protocol? : If i want to use nstream/nv2, . with above configuration [ Main: AP-Bridge, Client- Bridge/station-bridge] what configuration required at both ends?
  6. There may be 20-50 customer max on one Omnitik . total bandwidth not more than 5-10mbps.
    Should I set data rate or tx-power manually?
  7. Is any use of HT here?
  8. Is setting wds dynamic/static make performance changes?
  9. Currently I am using Main- AP-Bridge, Client-Bridge, Issue is sometimes heavy flooding and customers frequently get disconnected.
  10. My Clients also get frequently disconnected reason- datafrom unknown device- sent deauth.
Appreciate everyone's help . But I want to create standard document and performance parameters if any others effecting my link.
Requirement is simple Omnitik + Client [ all MT], distance 5 kms. Should work rock-solid. Which is not case right now :frowning:
Client Config
0 R name="wlan1-gateway" mtu=1500 mac-address=00:0C:42:F0:DE:1B arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name="mparmar"
mode=bridge ssid="singh8028" area="" frequency-mode=superchannel country=no_country_set antenna-gain=0 frequency=5350 band=5ghz-a/n channel-width=20mhz
scan-list=default wireless-protocol=any rate-set=default supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps
max-station-count=2007 distance=dynamic tx-power-mode=default noise-floor-threshold=default nv2-noise-floor-offset=default periodic-calibration=default
periodic-calibration-interval=60 dfs-mode=none wds-mode=dynamic wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=yes security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,
mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 tdma-period-size=2
nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key="" hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
rate-selection=legacy [/i][/i][/i]
Main Link Config
[admin@AP-BRIDGE] /interface wireless> print advanced
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:CD:CE:D1 arp=enabled
radio-name="AP-BRIDGE" mode=ap-bridge ssid="singh8028" area=""
frequency=5350 band=5ghz-a/n channel-width=20mhz scan-list=default
54Mbps
basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic
wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192
ht-amsdu-threshold=8192 tdma-period-size=2 nv2-queue-count=2
rate-selection=advanced multicast-helper=default
  1. for a multipoint configuration is the AP- Bridge. for a point to point is birdge
  2. bridge station is the best .
  3. change it to 20MHz, remember you have to spend a lot of traffic and you need space in which to pass.
  4. the superchanel you can use if you want to transmit outside of the standart channels, but also remember that the CPE should be able to transmit on those channels, and above all be careful in your region licensed to transmit on other channels.
  5. I prefer to use unknow, NV2 lacks even make improvements as far off clients, maybe with this latest version had improved but I personally have not tried it yet.
  6. The speed depends on what you consume your customers, I have used maximum of 20 clients per AP and still have achieved a decent performance.
  7. if the four active ht to take advantage of the double check polarity.
    :sunglasses: Wds I use when I want to spend entire networks from one place to another, I mean a LAN to LAN connection to the AP-Client connection is best ap-bridge and bridge station. Wds mac adrress transmits all from one place to another and that takes away performance.
  8. this can occur for weak signals or interference, omnitik has an omni directional and receives signals from the 360 ​​degrees, in addition to this the antenna gain is low, so I estimate about 3 to 4km of coverage, unless large antennas use customer side to compensate for the omnitik.
  9. when a CPE that does not have the same ssid than your app and do a scan, to find your app will negotiate the connection, but does not belong to this is ruled out and that’s the message you send.
  10. para un multipunto la configuracion es AP-
    Bridge. para un punto a punto es birdge
    2)station bridge es la mejor.
    3)cambialo a 20Mhz, recuerda que tienes que pasar mucho trafico y necesitaras espacio por donde pasarlo.
    4)el superchanel lo puedes utilizar si quieres transmitir fuera de los canales estandar, pero recuerda que el cpe tambien debe de poder transmitir en esos canales, y sobre todo tener cuidado con la licencia en tu region para transmitir en otros canales.
    5)yo prefiero utilizar unknow, NV2 aun le falta hacerle mejoras ya que desconecta mucho a los clientes, quizas con esta ultima version hubieron mejoras pero yo en lo personal no lo he probado aun.
    6)La velocidad dependera de lo que consuman tus clientes, yo he utilizado maximo de 20 clientes por Ap y aun he logrado un desempeno decente.
    7)si en ht activa los cuatro check para aprovechar la doble polaridad.
    :sunglasses:Wds yo lo utilizo cuando deseo pasar redes enteras de un lado a otro, osea una conexion de lan a lan, para la conexion AP-Client lo mejor es ap-bridge y station bridge. Wds trasmite todas las mac adrress de un lado al otro y eso te quita rendimiento.
    9)esto puede ocurrir por senales debiles o interferencia, omnitik posee una antena omni direccional y recibe senales de los 360 grados, ademas a esto la ganancia de la antena es baja, asi que yo calculo unos 3 a 4km de cobertura, a menos que utilices antenas grandes del lado de los clientes para compensar la del omnitik.
  11. cuando un cpe que no posee el mismo ssid que el de tu ap y hace un escaneo, al encontrar tu ap va a negociar la conexion, pero al no pertenecer a esta es descartado y ese es el mensaje que te envia.
Thanks a lot. I didnt understood 8th Answer.
If I set station-wds on client, will this come into picture and will it effect?
Another thing. I have pppoe setup on one central server, and all traffic comes to it, which not desirable.
Any solution for the same?
If I setup a pppoe server in between but still wants to limit bandwidth from main PPPOE server. Is it possible?
The middle server will talk to radius.
