How does MT identify P2P? If I set a mangle rule and flag all P2P, what actual criteria is used to do that determine what should be flagged? Is it possible to be catching other stuff? I am asking because I think some other things are hitting that flag.
I’m going to post my mangle rules and queue rules so that anyone who has the time can check them out. You can cut and past them into your test unit if you wish. That should work if you don’t already have rules.
It is a very simple setup. I just want to prioritize all traffic, and limit only P2P.
/ip firewall mangle
add action=mark-packet chain=prerouting comment=OSPF* disabled=no \
new-packet-mark=ospf passthrough=no protocol=ospf
add action=mark-packet chain=prerouting comment=ICMP* disabled=no \
new-packet-mark=icmp passthrough=no protocol=icmp
add action=mark-packet chain=prerouting comment=TCPACK* disabled=no \
new-packet-mark=tcpack packet-size=0-40 passthrough=no protocol=tcp \
tcp-flags=ack
add action=mark-packet chain=prerouting comment=SMALL-TCP* disabled=no \
new-packet-mark=tcp-small packet-size=0-192 passthrough=no protocol=tcp
add action=mark-packet chain=prerouting comment=HTTP* disabled=no port=80 \
new-packet-mark=http passthrough=no protocol=tcp
add action=mark-packet chain=prerouting comment=SMALL-UDP* disabled=no \
new-packet-mark=udp-small packet-size=0-192 passthrough=no protocol=udp
add action=mark-packet chain=prerouting comment=IPSEC* disabled=no \
new-packet-mark=ipsec-esp passthrough=no protocol=ipsec-esp
add action=mark-packet chain=prerouting comment=SSL* disabled=no port=443 \
new-packet-mark=ssl passthrough=no protocol=tcp
add action=mark-packet chain=prerouting comment="WOW Gamerz" disabled=no \
new-packet-mark=WOW passthrough=no port=3724 protocol=tcp
new-packet-mark=WOW passthrough=no port=6112 protocol=tcp
new-packet-mark=WOW passthrough=no port=6881-6999 protocol=tcp
add action=mark-packet chain=prerouting comment=MESSANGER* disabled=no \
port=1863 new-packet-mark=msn-messenger passthrough=no protocol=tcp
add action=mark-packet chain=prerouting comment=POP-3* disabled=no port=\
110 new-packet-mark=pop3 passthrough=no protocol=tcp
add action=mark-packet chain=prerouting comment=SMTP* disabled=no port=25 \
new-packet-mark=smtp passthrough=no protocol=tcp
add action=mark-packet chain=prerouting comment=IMAP* disabled=no port=\
143 new-packet-mark=imap passthrough=no protocol=tcp
add action=mark-packet chain=prerouting comment=GRE* disabled=no \
new-packet-mark=gre passthrough=no protocol=gre
new-packet-mark=ipsec-ah passthrough=no protocol=ipsec-ah
add action=mark-packet chain=prerouting comment=IPENCAP* disabled=no \
new-packet-mark=ipencap passthrough=no protocol=ipencap
add action=mark-packet chain=prerouting comment=IPIP* disabled=no \
new-packet-mark=ipip passthrough=no protocol=ipip
add action=mark-packet chain=prerouting comment=WinBox disabled=no \
new-packet-mark=tcp-other passthrough=no port=8291 protocol=tcp
add action=mark-packet chain=prerouting comment=MEDIUM-UDP* disabled=no \
new-packet-mark=upd-medium packet-size=193-512 passthrough=no protocol=\
udp
add action=mark-packet chain=prerouting comment=OTHER-UDP* disabled=no \
new-packet-mark=upd-other packet-size=513-1500 passthrough=no protocol=\
udp
add action=mark-packet chain=prerouting comment=MEDIUM-TCP* disabled=no \
new-packet-mark=tcp-medium packet-size=193-512 passthrough=no protocol=\
tcp
add action=mark-packet chain=prerouting comment=OTHER-TCP* disabled=no \
new-packet-mark=tcp-other packet-mark=!p2p packet-size=513-1500 \
passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting comment=YouTube* disabled=no \
new-packet-mark=Youtube passthrough=no src-address-list=Youtube
add action=mark-packet chain=prerouting comment=P2P* disabled=no \
new-packet-mark=p2p p2p=all-p2p passthrough=yes
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
max-limit=0 name=GLOBAL packet-mark="" parent=global-total priority=8 \
queue=default
max-limit=0 name=GRP-1 packet-mark="" parent=GLOBAL priority=1 queue=\
default
max-limit=0 name=GRP-2 packet-mark="" parent=GLOBAL priority=2 queue=\
default
max-limit=0 name=GRP-3 packet-mark="" parent=GLOBAL priority=3 queue=\
default
max-limit=0 name=GRP-4 packet-mark="" parent=GLOBAL priority=4 queue=\
default
max-limit=0 name=GRP-5 packet-mark="" parent=GLOBAL priority=5 queue=\
default
max-limit=0 name=GRP-6 packet-mark="" parent=GLOBAL priority=6 queue=\
default
max-limit=0 name=GRP-7 packet-mark="" parent=GLOBAL priority=7 queue=\
default
max-limit=0 name=GRP-8 packet-mark="" parent=GLOBAL priority=8 queue=\
default
max-limit=0 name=OSPF packet-mark=ospf parent=GRP-1 priority=1 queue=\
default
max-limit=0 name=ICMP packet-mark=icmp parent=GRP-1 priority=2 queue=\
default
max-limit=0 name=SSL packet-mark=ssl parent=GRP-2 priority=2 queue=\
default
max-limit=0 name=HTTP packet-mark=http parent=GRP-2 priority=3 queue=\
default
max-limit=0 name=TCPACK packet-mark=tcpack parent=GRP-1 priority=2 queue=\
default
max-limit=0 name=SMALL-UDP packet-mark=udp-small parent=GRP-1 priority=4 \
queue=default
max-limit=0 name=POP-3 packet-mark=pop3 parent=GRP-3 priority=3 queue=\
default
max-limit=0 name=IMAP packet-mark=imap parent=GRP-3 priority=3 queue=\
default
max-limit=0 name=SMTP packet-mark=smtp parent=GRP-3 priority=3 queue=\
default
max-limit=3072000 name=P2P packet-mark=p2p parent=GRP-8 priority=8 queue=\
default
max-limit=0 name=YOUTUBE packet-mark=Youtube parent=GRP-8 priority=7 \
queue=default
max-limit=0 name=MED-UDP packet-mark=upd-medium parent=GRP-2 priority=1 \
queue=default
max-limit=0 name=OTHER-UDP packet-mark=upd-other parent=GRP-6 priority=4 \
queue=default
max-limit=0 name=MESSANGER packet-mark=msn-messenger parent=GRP-2 \
priority=2 queue=default
max-limit=0 name=GRE packet-mark=gre parent=GRP-2 priority=4 queue=\
default
max-limit=0 name=IPSEC-ESP packet-mark=ipsec-esp parent=GRP-2 priority=4 \
queue=default
max-limit=0 name=IPSEC-AH packet-mark="" parent=GRP-2 priority=4 queue=\
default
max-limit=0 name=IPENCAP packet-mark=ipencap parent=GRP-2 priority=8 \
queue=default
max-limit=0 name=IPIP packet-mark=ipip parent=GRP-2 priority=8 queue=\
default
max-limit=0 name=SMALL-TCP packet-mark=tcp-small parent=GRP-1 priority=3 \
queue=default
max-limit=0 name=MED-TCP packet-mark=tcp-medium parent=GRP-2 priority=1 \
queue=default
max-limit=0 name=OTHER-TCP packet-mark=tcp-other parent=GRP-6 priority=4 \
queue=default
max-limit=0 name=WOW packet-mark=WOW parent=GRP-2 priority=6 queue=\
default
Thanks in advance;
-m-
