Identity
Hi there! Would like to get my local gateway IP to mikrotik identity. How can i do that?
If I’m understanding your question correctly, you’re trying to set your Mikrotik device identity to the local IP of your gateway.
Making the following assumptions:
  • Your trying to set the identity of a device that is not your gateway
  • You only have one route to worry about
You can set the identity of your device with
/system identity set name=<NAME>
Assuming a simple network, you’re only going to have one line of output for ‘/ip route nexthop print’, so you can get your gateway’s local IP with
/ip route nexthop get 0 address
Knowing that, you can get your identity to your gateway’s local IP with
/system identity set name=[/ip route nexthop get 0 address]
If you potentially have more than one line of output for /ip route nexthop print, you can grab the address for the line with a reachable gateway with
/ip route nexthop get [/ip route nexthop find where gw-state=reachable] address]
Now let’s assume a different topology:
  • You have a Mikrotik device directly behind your ISP gateway
  • You want to set your Mikrotik device identity to the internal (LAN) IP of your ISP gateway (your “gateway” from a routing perspective)
The same line works :smiley:
The next hop from your Mikrotik device on the edge to your ISP gateway will be your ISP gateway’s customer-facing IP (not your public IP).
I hope one of those two scenarios answers your question, or at least gets you started.
Cheers
