Idiots guide to setting up Wireguard client
I’m trying to get my router to act as a wireguard client for NordVPN so that all the internet traffic from local network gets routed through the VPN. There are a few posts on the forum that all reference this post: https://forum.mikrotik.com/viewtopic.php?t=182340 . I have attempted to read through it and I’m afraid it might as well be written in Chinese - I have zero idea where I should even start. Does anyone know of an idiot-proof step-by-step guide that doesn’t require extensive understanding of networking to make sense?
Thanks!
Ok, so piecing together various different tutorials from around the internet I’ve ended up with this config, which I think is more or less correct for the NordVPN side, but I’m still stuck on exactly how I should setup the NAT/routing side so that all my traffic goes via the Wireguard connection:
# 2023-09-28 17:28:23 by RouterOS 7.11.2
# software id = DNSC-DX1W
# model = RB750Gr3
add admin-mac=18:FD:74:74:08:BC auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes dial-on-demand=yes disabled=no interface=ether1 \
    max-mru=1492 max-mtu=1480 name=pppoe-out1 user=XXXXXXX
/interface wireguard
add listen-port=37728 mtu=1420 name=nordvpn
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=0.0.0.0/0 comment=uk2220.nordvpn.com endpoint-address=\
    178.239.162.243 endpoint-port=51820 interface=nordvpn \
    persistent-keepalive=40s public-key=\
    "K53l2wOIHU3262sX5N/5kAvCvt4r55lNui30EbvaDlE="
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
add address=10.5.0.2/24 interface=nordvpn network=10.5.0.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    ipsec-policy=out,none out-interface-list=WAN src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment="defconf: allow nordvpn" \
    out-interface=nordvpn
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=RouterOS
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Note: I don’t use nordvpn nor wireguard, so this message is a best effort to put you on the right track.
  1. extract nordvpn configuration to be used with wireguard. Follow these steps : https://www.reddit.com/r/PFSENSE/comments/m0989o/nordvpn_wireguard_setup_works/ (there is a link to an image which tells you which information to use)
  2. read documentation: https://help.mikrotik.com/docs/display/ROS/WireGuard as next steps depend on it
  3. set up wireguard interface (check above image to get listen port, private and publik keys)
  4. set up peer configuration (check above image to get endpoint address, port and peer public key) + define allowed addresses
  5. configure ip and routing
  6. configure firewall
It does’nt seem that complicated once you have done step 1.
Good luck !
Yeah so I’ve done 1-4, I think. But I really don’t understand routing or ip configuration, especially in router OS so I was hoping someone could just tell me what I needed to do :-/ The documentation all seems to assume a level of networking knowledge that I just don’t have…
Well the link at step 2 explains what to do… “IP and routing configuration” and “Firewall considerations” sections, you just need to replace the IP addresses with the ones of your context.
If you want more it’s not an “idiot guide” you’re looking for but an “idiot doing the configuration for you”. :wink:
Note: in your configuration, you don’t seem to have set the private/public keys for the interface, so add them (without pasting them here) + make sure that you use values you extract from the client’s configuration and not values you find on the internet.
I did try reading this page but the big problem I have is that basically all the information relates to either mutually peering two office networks which are both connected directly to the public internet with public ips on the routers; or a RoadWarrior setup where the router is acting as a Wireguard server. I want neither of these and I’m struggling to see which bits relate to my requirement (router as a wireguard client routing all external traffic over the VPN; router connected to the internet with PPPoE behind double NAT
I’m not sure what happened with my config export here but I do have this setup. It’s possible that I was over-zealous when pruning the config for public posting. I extracted the keys using the nordvpn linux client.
I’m going to try to fiddle with this again and see I can make it work, but I still feel like I’m semi-randomly changing settings without having an real understanding of what I’m doing. As best as I can tell:
  • Firewall considerations: this is irrelevant to me. I don’t need anything to establish an inbound tunnel so I don’t need to poke a hole in my firewall for this. Or have I got this wrong? Does Wireguard require a mutual connection in every scenario? I think the same applies to the forward chain because I’m not routing specific subnets
  • Routing considerations: I’ve added an address for the VPN:
/ip address add address=10.5.0.2/24 interface=nordvpn network=10.5.0.0
but the routing information from the manual page clearly isn’t relevant to me because it relates to routing a specific subnet over the VPN. This is the bit that I’m really struggling with. I’m guessing I need to fiddle with my NAT configuration but I can’t find an examples of how to do this that are sufficiently close to what I have (WAN routed over PPPoE with NAT)
I’m inching towards understanding this/getting it working but there’s still one piece of the puzzle missing i think. Here’s my config so far:
# 2023-09-30 12:11:50 by RouterOS 7.11.2
# model = RB750Gr3
    max-mru=1492 max-mtu=1480 name=pppoe-out1 use-peer-dns=\
    yes user=XXXXXXXXXXXXX
add listen-port=37728 mtu=1420 name=nordvpn private-key=\
    "XXXXXXXXXXXXXXXXXXXXXX"
/ip hotspot profile
/port
set 0 name=serial0
/routing table
add fib name=useNordVPN
/ipv6 settings
set disable-ipv6=yes
add interface=nordvpn list=WAN
    " 178.239.162.243" endpoint-port=51820 interface=nordvpn \
    192.168.1.0
/ip dhcp-client
/ip dns static
    invalid
add action=accept chain=forward in-interface-list=LAN out-interface=nordvpn
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup src-address=192.168.1.0/24 table=useNordVPN
/system clock
/system note
/tool mac-server
Things that I’ve done:
  • Added the wireguard interface + peer with appropriate keys pulled from the nordvpn linux client. I believe this part is working correctly
  • Added a 10.0.5.2/24 address for the nordvpn tunnel
  • Added a forward firewall rule to allow LAN traffic into the tunnel
  • Added the nordvpn interface to the WAN interface list so that the existing src-nat masquerade rule will apply to it
  • Added a routing table + routing rule as specified in 7.4 of this: https://forum.mikrotik.com/viewtopic.php?p=906311#p906311
Now obviously it doesn’t do anything yet because I haven’t actually added a route to the new routing table. And this is where I’m stuck. If I do this:
/ip route add distance=1 dst-address=0.0.0.0/0 gateway=nordvpn pref-src=""  routing-table=useNordVPN scope=30 suppress-hw-offload=no target-scope=10
My entire network dies and I can’t even reach the router any more. The first time I did this, I didn’t have winbox setup and I had to factory reset the router and rebuild my network from scratch. So that was fun.
I’m wondering if this has something to do with the strange double NAT setup that my ISP has. Here’s my current list of routes before adding the extra route for wireguard:
 Av   afi=ip4 contribution=active dst-address=0.0.0.0/0 routing-table=main pref-src="" gateway=pppoe-out1 immediate-gw=pppoe-out1 distance=1 scope=30 target-scope=10 vrf-interface=pppoe-out1 belongs-to="vpn"
       debug.fwp-ptr=0x20242000
 Ac   afi=ip4 contribution=active dst-address=10.5.0.0/24 routing-table=main gateway=nordvpn immediate-gw=nordvpn distance=0 scope=10 belongs-to="connected" local-address=10.5.0.2%nordvpn
       debug.fwp-ptr=0x20242120
 Ac   afi=ip4 contribution=active dst-address=192.168.1.0/24 routing-table=main gateway=bridge immediate-gw=bridge distance=0 scope=10 belongs-to="connected" local-address=192.168.1.1%bridge
       debug.fwp-ptr=0x20242060
 Ac   afi=ip4 contribution=active dst-address=192.168.207.1/32 routing-table=main gateway=pppoe-out1 immediate-gw=pppoe-out1 distance=0 scope=10 belongs-to="connected" local-address=192.168.207.239%pppoe-out1
       debug.fwp-ptr=0x202420C0
 A H  afi=link contribution=active dst-address=ether1 routing-table=main distance=0 belongs-to="interface"
 A H  afi=link contribution=active dst-address=ether2 routing-table=main distance=0 belongs-to="interface"
 A H  afi=link contribution=active dst-address=ether3 routing-table=main distance=0 belongs-to="interface"
 A H  afi=link contribution=active dst-address=ether4 routing-table=main distance=0 belongs-to="interface"
 A H  afi=link contribution=active dst-address=ether5 routing-table=main distance=0 belongs-to="interface"
 A H  afi=link contribution=active dst-address=bridge routing-table=main distance=0 belongs-to="interface"
 A H  afi=link contribution=active dst-address=pppoe-out1 routing-table=main distance=0 belongs-to="interface"
 A H  afi=link contribution=active dst-address=nordvpn routing-table=main distance=0 belongs-to="interface"
Can anyone suggest what I need to add as a route to get just my public internet traffic to leave via the VPN?
Gah ok so I had a space in front of the endpoint address for my wireguard peer. Removing that, it now works - sort of. The VPN is active, and traffic is routing via it as expected. But there’s one remaining problem: I can’t reach the router by IP address. I can reach other machines on the local network, but while the VPN route is enabled, pinging or opening 192.168.1.1 in a web browser doesn’t work. Any ideas?
Can I get your running config file for the wireguard client on mikrotik router?
